I have 2 8800 GTX's, and when I look in Everest, it lists them at different voltages.
I want to get them both to the 1.4 (1 is listed at 1.3 and the other at 1.4)
Obviously they are the same card (one is black PCB the other is green) so the only real difference must be the bios. I have been reading about a program called
Nibitor
and I know you can flash bios's and stuff. Would it be safe for me to take the bios off my one card and put it on the other as well? Does it matter if the ram chips are different? Like if one uses samsung ram and the other hynix?
Just currious. I cant get a definitive answer on if volt moding can be done via Nibitor or not. WHAT IS THE VOLTAGE TABLE EDITOR in Nibitor?
also, I noticed this bios and it says 1.47 volts, does that mean this bios is set to 1.47?
http://www.techpowerup.com/vgabios/5561/EVGA.8800GTX.768.070103.html
Nibitor
