Bios upgrade help
Vitamin T
This is driving me absolutely up the chimney. Went to Epox, downloaded the BIOS upgrade. It's in the form of a bin file (along with an executable). Every program I use, which is pretty much every shareware burning app known to man, says it is NOT a valid file. Specifically, a valid "ISO file". I KNOW it's not an ISO file, it's a BIN file! Someone please help this ignorant [H]fuck.
I should add, I was able to convert it into a smaller TAO file, but that's leading me nowhere too...
Thanks for the help guys.
Ummm...read the flashing instructions...
You have to make a bootable floppy...then put the flasher program and the .bin file (which is your BIOS) on the disk...boot from it, run the flasher program, then enter in the name of the BIOS .bin file.
EDIT>>>
I downloaded your BIOS...after you boot from your floppy type in awdflash and that will bring up the flash/programming program...it will then ask you the name of the file to be programmed...then you type in the name of the .bin... 9ND35202.BIN or whatever version you downloaded...it will ask you if you want to save the old BIOS...I usually do, and name it old.bin. It will save the old then program the new...reboot and go into your BIOS settings and adjust them to your liking (as some flashes reset the BIOS to default.)
I don't have a floppy dirve (who needs em?...until now). Is it "ok" to just flop both files onto a cd and boot from it? Will it work the same way?
Yes it should...as long as you have a DOS boot CD that will load a dos driver for CD-ROM support ...then the BIOS files on the same or another CD. I put some further instructions above on my other post.
LOL...true...however, this the reason I still have a floppy in my systems...it's the easiest way for BIOS updates.
And me, like a dummy, opted for the Soyo BayOne so my GF can more easily load up the pics from her camera via flash. USB ports, audio in/out ports, but no floppy :(
OK, I'll try and do what you suggested above with a CD (directly burning the files doesn't work - didn't think it would.) Thanks - I'll let you know how it goes.
Awesome. Winflash worked like a charm. At least it looks like it did. My ram still won't get out of 166mhz mode. But I guess that's a question for the mem forum :D
