Bios Updade?
mikesroth
I wanted to ask a quick question, as I haven't run into this 'Issue' before.
I have been looking at upgrading to the AMD Athlon 64 3000 (939) with the MSI K8N Neo4 Platinum Ultra motherboard. I saw on another Web Forum that 'sometimes' you need to purchase a BIOS chip because the BIOS is too outdated to support the CPU. First off, Is this true? Secondly, do you think that I would have this issue with this setup?
Thanks!!!
Michael
i highly doubt that's true. if there was an actual problem with the flash rom then it would be replaced in the next revision. otherwise, a new bios flash would solve whatever problems there previously were. i can only think that replacing that IC is obsurd.
that setup should work fine.
Thanks for Replying!!! I just found the 'compatiblity' matrix on the MSI site. Must have been really sleepy when I was looking last night. :D
