For some reason after transferring the contents of my PC to a new case (Antec Sonata), I now have to wait at least 45 seconds for my bios to detect my IDE drives! Now the obvious factor here is the cables are bad, but I can still do everything on both HDs just fine in windows and there doesn't appear to be any sort of slow-down. I have 4 IDE drives in my system: 1 80 GB Maxtor, 1 120 GB Maxtor, 1 LG DVD burner and 1 Liteon CDRW. The HDs are on primary IDE 1 and the optical drives are on IDE 2. Before I transfered my system my drives were detected just fine, without the wait. This is my system:
Antec Sonota with 380 Watt True Power, power supply
P4 3.2E @ 3.6
2x512 MB Ram
Radeon 9800 Pro
Asus P4P800 motherboard
Echo Mia soundcard
XP-120 HSF with 120mm Panflow
I really did have to kinda bend the cables in ackward ways to make them fit, but I still don't understand how if the cables were broken the drives would function or be detected. I have set the drives up with 32bit access enabled in the bios and I also have selected UDMA 5 for both HDs as that is what the bios seems to detect them as.
Does anyone have any ideas?
Thanks
P4 3.2E @ 3.6
2x512 MB Ram
Radeon 9800 Pro
Echo Mia soundcard
Thanks
