Bios slow to report cpu...
mwalt2
The first screen of the bios (the one that reports cpu speed, memory, fsb, etc) when booting my computer is taking longer than normal to display. My motherboard is an Abit IC7. I have tried the newest bios and also reverted back to an older bios, but it still takes a long time for it to show the cpu speed when booting (sometimes it will just say "Inte " and after awhile it puts the rest of Intel there, sometimes it doesn't even show the cpu info, only the memory size). It used to only take a couple of seconds to report the cpu/mem info, but now it takes around 30 seconds or so. I have cleared CMOS and even removed the battery for a few minutes. It seems to be hanging on something during the initial startup, but I can't figure out what or why.
Post the rest of your system specs...including the PSU capacity...What I mean by that is not whats written on the side like "400W" I mean what are the amperage (A) specs for each voltage on the side of the power supply for:
3.3V
+5V
+12V
+5VSB
During post or bootup the drives are sucking up a lot of juice, all electrical motors will do this...If the board is getting less than nominal voltage and current things WILL slow down..
MD
I've had the exact same problem and found that is a faulty floppy disk drive. Try disconnecting any floppy that you have installed and see if that does the trick. If that helps, then make sure that you have not installed the floppy cable upside down, as that can cause the same issue.
Also be sure to check your master/slave settings on all of your drives one more time and be sure they are as they should be.
Thanks for the replies. My specs are: 350W Fortron PSU, Abit IC7, P4C3.0 Ghz, 1 gig kingston hyper-x pc3500, 36 gb raptor, 200 gb WD HDD, audigy 1 soundcard, ATI 9800 AIW, NIC, floppy, and a nec2500a dvd drive.
Under 100% CPU load:
+3.3V = 3.26
+5V = 5.00
+12V = 11.67V
-12V = -7.76
-5V = -2.99
+5VSB = 5.48
I will also try disconnecting the floppy drive. It has worked fine since I built it (10 months ago), so something is probably going bad.
+3.3V = 3.26
+5V = 5.00
+12V = 11.67V
-12V = -7.76
-5V = -2.99
+5VSB = 5.48
wow!...11.67v at 350watt...that would be frightening to me...i think that raptor is taking alot of power...and you should get a new PSU..i recomend Antec PSUs...get a new one and see if that helps...you should get at least a 430 and 500 topps to support your power hungry drives...
It's still within the 5% load reg. of the PSU specs. When my computer is idle, the +12V is 11.9 V. I don't think the PSU is the problem. It ran fine for the first 10 months, part of the time with another HDD in the machine. This slow bios load just started happening a few days ago.
I was looking for the Amps on each line...The volts are within spec, no one cares about the negatives anymore though...
