BIOS Settings?
In my Phoenix Bios of my eMachines 6805 I see a couple of settings that I have no idea what they do.
PXE Function and RF Power Control.
What are these for and should they be enabled?
thx
-Cjh
Shamelessly copied from here
PXE is Intel's Preboot Execution Environment standard. This specifys a minimum level of functionality a boot ROM must supply to an IPL or a bootable image. These functions are broken down into 4 catagories. The Preboot, TFTP, UDP and the UNDI APIs. The preboot contains the overall control and information functions. The UDP API supports the User Datagram Protocol. The TFTP API supports the Trivial File Transport Protocol, and the UNDI API is Intel's name for the Universal Network Driver Interface
So effectively PXE is for booting from a lan.
RF Power Control should have something to do with onboard wireless lan?
RF = Radio Frequency Power Control which means if its an enable/disable option you can enable it to adjust the power output of the RF card you are using or if its a % number or something you might be adjusting it in bios
