BIOS question
MoBsTa
My motherboard is an ASUS A8VE-DELUXE. I just built a new computer with it and the BIOS needs to be updated.
One of the ways I can do this is through the internet. It sounds too easy, though. Is it safe to do it through the internet? Or should I just stick with the floppy solution.
I have a P4P800 Deluxe and it had some manner of utility to do it another way but I just stuck with the trusty old floppy lest the internet connection gets broken or windows freezes or whatever. Can't go wrong with the old school, but I'm sure the other utility will work fine as well.
i have a a8v deluxe and i did put the new beta bios on it-- i did use the software ez-updater to flash the new bios . i downloaded the bios and flashed from a file.
had no-problems at all.
however-- my other 939's with the nf4 chipset i have been useing award flash to update the bios on them.
the a8n-sli deluxe seems to hate the software flash utility --it keeps forgetting settings when flashed with the windows based tool.
the DFI ultra D has a software flasher win-fast - i haven't used it--might work ok.
-but i'm sticking with the award flash for all the nf4s i work with .
so itseems to depend on the chipset --some chipsets seem to "like" windows type flash utilities while others seem to demand award-flash from a floppy.
you should be able to update the bios with the windows tool OK with the via type MB. :cool:
