BIOS Problems
captain204mike
Hello
Can someone help me out here, i have a asus A8N-SLI-Deluxe, Motherboard
i had a x2 3800 processor in this thing and had it overclocked, bought a new processor and was told to set the MOBO back to defaults, so i went in to bios pressed F5 and reset board to defaults, put new processor in booted up, ran fine for a while and restarted it, now it wont boot back up at all, not even getting the first beep when it posts up at start. comes up with the window detecting IDE Atapi device, i guess this is where i recover the bios with the disk, so i did that, still nothing, put old proccessor back in and same thing.
so i reset the CMOS and took battery out, put back in and back to normal cmos setting, reboot and it boots back up, bios version looks older and says checksum error, press F1 to continue and it boots to windows, restart the pc and back to the same thing, no boot up, have to reset battery and cmos again to get to boot up
ANY SUGGESTIONS????????
sorry so long of a question
Thanks
When you reset the CMOS it more or less scrambles the CMOS RAM that hold the BIOS settings. A checksum is computed on the contents of the CMOS and doesn't match what's stored in the CMOS's checksum field (because it's either zero'd or scrambled). Thus BIOS will throw out a checksum mismatch error and halt the boot up. What you need to then is enter BIOS setup and set everything to how it's supposed to be, your harddrives, floppy drives, etc Save and exit, all should be fine.
So i need to restart, and im sure ill have to reset the cmos again and battery because it wont restart without doing that, and instead of letting it get to windows first, go to bios and just do a F5 for defaults, save it then restart it and will work fine??
Thanks
Thanks
No, go through each and every section and make sure the settings match how your computer is configured.
Question though. When the computer won't boot is there anything on the screen?
no when it wont boot my screen says no monitor or whatever that says when nothing outputting to it
i really dont know what all i would need to set in the bios ive always just used the defaults
plus now it is the old bios version because had to use the disk to recover it, and when i use the asus update utility it wont work??
One thing that comes to mind is that maybe your CPU is overheating, and resetting your CMOS allows it time to cool off enough to let you boot back up. When you put the new CPU in did you clean the old thermal paste of the bottom of the heatsink and reapply a new (very thin) layer of it on the CPU?
i actually bought a Zalmann and new processor and used the paste that came with the zelman
the one that i bought has heatpipes on it, and it goes over and almost, and i mean almost touches the first memory stick, is that ok?
i am using speedfan and it shows the processor at 33, so that looks ok, but im no expert so i dont know what it should be, that is at normal operating
as long as it doesn't actually touch it's okay.
Was the thermal paste preapplied (ie a perfect square on the bottom of the HS, or did you have to apply it yourself?
33 sounds good. When the computer does boot it's not locking up or "hitching/pausing" and is otherwise stable?
no it doesnt pause or anything just runs like a champ, i can run a stress prime for about 1 hour temps look good, no errors with processor,
im thinking it is the bios or something went bad
i did buy it off ebay, seller said new board, got it, and had no manual, book, cables, came in generic box, and the clip for pci express was broke, could tell it was used, so im talking with him now about getting it replaced, but no response from him
so guess i need to buy a new one
any suggestions for a board, i want 2 pci express sli
going to do some overclocking, socket 939, Sata, going to use that Opteron 170 chip
x1950xtx 512mb ddr4 Video
someone said DFI but im not familiar, just with ASUS
but im open for anything that will fit that match of stuff i have
buying computer equipment off of ebay is usually not a good idea for things that are available new.
I think I saw a deal on Newegg for a DFI Crossfire motherboard based on the ATI Xpress 3200 chipset for about $97 in the Hotdeals forum here. DFI was a great company for s939 motherboards, usually had very nice feature and overclocked nicely. I'll see if I can find it fo ya.
(just for clarification. for SLI you need an nVidia chipset such as NF4 SLI series, or NF 500 SLI series. and two nVidia Geforce graphics cards. Since you already have an ATI x1950xtx you'll need a ATI Xpress 3200 or Xpress 200 Crossifire based motherboard and add an x1950 Crossfire master card to get dual gpu funcionality)
so you think that would be the board to go with,
also will my Zalman CNPS8000 fit on this board, its tight right now with the ASUS
that price is cheap, is this a high end board?
im wanting to build something that will play kick a** games and last a little while
i mostly play Americas Army, Nascar Racing 2003 season, Microsoft Flight Simulator X
which takes a huge system
thanks so much for your help, any time i have had a question they were answered in like 5 mins on this forum, really really good forum
High end and socket 939 really don't go together anymore. AMD has killed off socket 939 in favor of socket AM2 and DDR2. The only reason 939 is still avaiable for so cheap is that there's leftover stock. Anyway, the DFI lanparty series of motherboards were considered high end when they were release. You shouldn't have any problems with your CPU and Graphics cards for a while yet.
However, when DX10 games start to hit the market you won't be able to take full advantage of what DX10 has to offer because the x1950xtx is only a DX9 card. That being said though, it'll probably be a good six months before DX10 games come out, and even then, they'll most likely have a DX9 compatibility mode. If later on you find that you want to try DX10 out, then all you'll need is a DX10 video card, and Windows Vista. You won't have to replace any other components
