BIOS problem...
birnx
I have managed to corrupt my bios on my Neo2 Platinum and I'm wondering if anyone knows where I can find a new bios chip or possibly a way of reviving it other than hot flashing it.
Try the manufacturer
or
badflash.com
Your in luck since the IC is socketed...
If it's hosed you could try the AMIBOOT.ROM trick?
You could luck out if your boot block is still intact.
On another computer:
Get a new floppy disk & use a full format and not a quick format for your floppy to prevent data errors.
Copy the BIOS rom file for your dead board to the floppy and rename it to "AMIBOOT.ROM" Windows may display the name as Amiboot.ROM. This is nothing to worry about. Just make sure your CAPS lock is on when you type it.
On the dead computer
Slap the floppy into the disk drive.
Restart the machine while holding down the Control and Home keys simultaneously until you hear 4 beeps. The BIOS should be flashed.
If that doesn't work, you can get another bios IC
MD
The mobo is comletely dead, it doesn't show any sign of power. So I'm going to try a chip from badflash I guess, I don't think I really have a choice at this point.
