Bios keeps losing settings when power cut off
Chris
This is the 2nd time I have experienced this wih different board.
First, Abit KW7, and now Shuttle AN335N Ultra.
Bios keeps resetting when the power cable is unplugged from the back of PSU for more than 10 min (all settings including date, & time). The CPU is overclocked at 1700@166x13. At non-overclocked setting, the bios seems to remember.
What could cause this ?
I've never had this problem before, but this year it happens twice with different mobos.
The funny thing is, it still holds the settings when power is disconnected for 2-3 min, but after 10 min or longer, it will reset the cmos data.
CMOS clear, new battery .....no help.
Anybody have any ideas ?
only 2 things I can think of that usually cause this. Dead battery or bad CMOS chip.
My A8n-sli does the same damn thing. Frustrating as hell, but it's a super stable mb otherwise, so I live with it. I changed the battery and still same. I look at it as bios practice, he.
My bets on the battery.
EDIT... shit, should have read a little better, I see you've already tried the battery...
I had this happen as well. Here's what cleared it up for me. . .
1. Bent the pins on the CMOS clear jumper so that it was making firmer conact with the jumper. And, of course, make sure you have the jumper in the right position!
2. Do the clear CMOS procedure, and take out the battery. Then, with the battery out and the jumper set to clear, hold down the power button on your computer for twenty seconds. This can release any pent up charge left in any capacitors (I'm not electrician, so go easy on me there).
That last bit was recommended for the Abit AN8 series when it too suffered from a "not retaining settings" problem. . . and it worked for a lot of people. Give it a shot. And, of course, you might try a newer/older BIOS revision.
H
H
IT WORKS. Looks like the CMOS jumper not making proper contact. I followed your suggestion, and now it retains the settings properly. Tested by unplugging the power cable from the back of PSU for 8 hours now, and it still retains the settings. THANK YOUUUUUU
You're very welcome. *feels warm and fuzzy* :D
