bios keeps getting wiped - what's going on?
NleahciM
so a friend's computer (which I built) is having some serious problems. Every time it loses power - the bios gets cleared. I had him replace the cmos battery - and the problem still persists. anyone know what could be going on?
Edit: Probably doesn't matter too much - but computer specs:
Abit IS-7
P4C 2.8Ghz
2x256mb pc3700 twinx
radeon 9800 pro
WD raptor 37GB
WD SE 120GB
Antex 3700AMB case
Thermalright SLK-800U (cooled by 120mm stealth)
I'm definitely not attempting to be sarcastic in any way, but have you double checked to make sure the CMOS jumper isn't on the reset pins?
Also, what kind of power supply is it? If it's too underpowered, I've heard this sort of thing to happen, although very rarely.
Dark Assassin
Dark Assassin
I can't check it - it's halfway across the continent from me. I already had him check though. The PSU is the 350W that is included with the Antec case.
i have a similar problem, where on startup first couple of seconds it will shut down.
I was having a similar problem where the computer would randomly shut off and it turned out to be bad RAM. Worth a shot I guess.
Dark Assassin
What is a CMOS?
The motherboard could be grounding out somewhere. Make sure there are no risers on the mobo tray that are touching the mobo where there isn't a hole for a screw. I am betting this is the problem considering I have had this exact same problem before and removing the mobo and checking underneath solved it. If there are risers that aren't being used remove them or put some electrical tape over them if they are unremoveable.
make sure he put the new battery in correctly.
Originally posted by ProXie
What is a CMOS?
The CMOS is a small part on your motherboard that basically holds your BIOS settings. It's powered by a small, disc battery (forget the model numbers) and can be reset to default settings by merely rearranging pin sequence.
Overclocking basically lives and dies by a simple CMOS setting.
Dark Assassin
im not counting my chickens, but i think i may have fixed the problem on my kg7-r by delaying the harddrives by 1 second.
He can't even get into the bios right now.
As for something shorting it - being the person that built this computer - I'd say that's rather unlikely. It was running perfectly for a month or so - but *almost* whenever it got unplugged the bios would get wiped.
Unless could a short be causing the battery to be drained or something? That's the only thing that would make any sense at all...
Originally posted by Dark_Eternal
Replace the Mobo battery. Should fix it right up.
Already tried that. Perhaps are there multiple types of batteries that are that same size?
