I made a mistake and bought the M9 instead of the TForce (TForce isn't available in my country as well).
I am not able to POST at anyt FSB above 256MHz regardless of settings/voltage. However, at 256MHz (+0.1V, 2.7V RAM), I could loop 2 instances of both large and small FTT Prime w/o any problems.
I tried to flash the BIOS on the board to the TForce version but it didn't work properly. Although I could set the timings and FSB etc, the Vcore and Vdimm settings didn't work.
Are there any modded versions of the TForce BIOS that have working Vcore and Vdimm on the M9? If not, could the problem be due to the integrated graphics? I was using the onboard rather than a gfx card though. Thus wondering if the onboard crap out at those FSB.
Btw, I am using an Opteron 170 (running 1 instance of small and Large FTT per core). RAM is 2 x 256MB Samsung TCCDs (tested to work at 300MHz 2.85V on Neo2 Plat).
Thanks.
Thanks.
