BLACK@BLUE
- Feb 24, 2012
Well I know you all are probably smarter than me so you may never run in to this issue.
I had bought parts for 2x 2p socket 1207 systems and had the parts sitting around, wife kept wanting to know when I was going to do something with this stuff I said I had to have. Went out bought a piece of wood and some 6 inch screews so I could mount the board one above the other, to keep the wife happy I put it all together before I had psu's. turned it on and nothing,
Ok cutting to the chase I needed bio's update on both boards to see the 2419 six cores, thinking of taking this stuff all apart to be able to remove the heatsinks and take out the cpu's and put a 2 core back in was gonna be a long task for the bottum board. I decided to flash the top boards bio's and then switch the bio's chip with the lower board, then did the top board again, replaced the cpu's and I was done.
I don't know if I could recommend this to anyone but it saved me a ton of time and headache.
