I was flashing my EVGA 790i FTW Bios and I lost power so now they are dead. I've been trying to fix the bios using the the floppy drive method but I can't figure out how exactly to do that.
EVGA doesn't have (proper) instructions on how to create a bootable BIOS disk?
Essentially, you need to create a bootable disk -- it can be a floppy, a CD/DVD, or (if your motherboard supports it) a flash drive -- that contains some OS system files. You then install the BIOS (and, if necessary, the BIOS installation/update software) onto the disk, reboot your system, and configure your BIOS so that the bootable disk can be read first.
However, if you can't access your BIOS at all, you may be stuck.
