Flashing to the X800 XT with a X800 Pro VIVO is not guaranteed. You may kill your card.xyber said:so, for example, the x800pro flashing to a x800xt-pe is safeproof unless the power goes out? Well of course when the power goes out due to a power outage, your comp at any state can fry a componant.
Well, it's entirely possible that a new revision of the VIVOs will come out and the BIOS flash might not work on it. That wouldn't be the first time it happened with ATI cards (the Saphire 9800LE was it?). Also, one (or more) of the four disabled pipes could be damaged or non-functional causing who knows what kind of side effects. There's even some reports that the flashed cards just start randomly dieing after a short amount of time, but it's mostly unsubstantiated.xyber said:Hmm... in what circumstances will it fry? Just attempting the flash?
