Board: ASUS P5N-SLI
want to flash bios to accept e4300, currently the set-up is barebones out of the case with a P4 in the CPU socket.
current bios=0601 Board is Rev. 2.00G which will take a 4300.
downloaded bios 1201 in a zip file, unzipped it. Transfered the file to both a floppy and a flash drive.
Under easyflash2:message: downgraded file not suitable for system
Under Awardflash utility: Message: source file not found.
I dont get it. I followed the manual to the letter, both for easy flash and award flash.
I even tried an earlier bios version and different floppy and flash drives.
i wonder if I should put the 4300 in and see if it posts and the try the flash again........do you suppose the "system" wont flash the bios because it currently has a single core and I want to flash a dual core bios???? just grasping for straws.
Help appreciated.
Help appreciated.
