RawsonDR said:I've never done it but it seems like it would work.
Make a bootable CD ( http://www.bootdisk.com/ ) and throw your flash utility and BIOS on it. Run the utility when you get a command prompt.
The only problem I can foresee is if the flash utility tries to write to the drive where it's located, like to create a log entry of the flash or something.
Your board doesn't support a windows flash program? (although they aren't ideal)
MD_Willington said:It works, in fact you can make a boot disk and put all of the latest drivers, bios, flasher, utilities, etc onto the CDR, makes a good troubleshooting or setup disk too.
MD
