Bios flash probs
Mayhempball
I have a MSI K7t pro2, and am trying to flash the bios,i boot it to the "a" drive, but i cant get it go to the "c" drive like the instructions say. I used a boot disc i made off of a my laptop which is running XP home, and the K7T system is also running XP home. What could be causing this, and is there another way to do it?
Thanks
anyone? I keep getting a invalid drive specification with the XP disc. I go out to sea tomarrrow, like to figure this out before i leave
thanks
http://www.msicomputer.com/support/bios_result.asp
Sorry that no one answered you before you went to sea. Sincerely hope you get some off time to check out the "how to's" and support files listed here..... (and just to chill ...most importantly! ) This link will guide you to solve your problem better then anything.
Wherever at sea you may be at this moment, (and for whatever purpose at all) , that finds you on a deck, on a sea.....
Godspeed buddy! :)
