i have done some searching and haven't found an answer so i thought i would post here. I need to flash my asus A7V333 mobo but don't have (nor want) a floppy drive. How can I create a boot cd to flash from? is this even possible?
the bios file and flasher
a boot image (which are all over the web)
Nero 6.0 or higher
You just go to Nero, Data disk, File, new, on the left are options - click on boot CD
(or go to make bootable cd directly)
steer the boot tab to the image and click it in (uncheck A)
change iso to 31 characters, relax iso restrictions - check all
click new
drag your awardflash and bios file (not in a folder) to the compile window and burn
set your PC to boot from CD first
command prompt from there
yeah. you have to boot to the cd, in dos, then run the flash software, which runs in dos. only problem is when im in dos it can't see the files on the cd. it only sees the system files.
