Blinkme323
- Feb 8, 2005
Hi, I've been using my Sapphire X850XT for a couple weeks. It runs fine at 560/640 with absolutely no artifacting. I wanted to flash to a new bios so I didnt need ATi Tray Tools constantly running to apply the overclock and have it adjust the fan speed every startup.
I used the X850Xt-PE Bios because I heard that helps with overclocking a little bit. I set the clocks to 550/630 and did the fan speed controls with Rabit. I used ATI Winflash to flash the card.
It seemed to work fine, but on restart the entire screen is pixelated and multi colored. You can't see anything. Any idea's what went wrong and how I can restore my card?
