Bios flash for PNY 4600Ti?
I have been looking for a place that has a bios for the 4600Ti. I actually found a rom but have no idea how to flash this thing. I dont know where to find a flash utility for this and I dont even know if this rom flash will work in the PNY. I found it on some site and it doesn't name any mfgs. Does it matter or will any flash for this particular chip work? And if anyone knows of a site where I can get the whole flash package for this thing, please let me know. Thx.
It would need to be another TI4X00 BIOS, but a different manufacturer should work. Instead of showing up as a PNY card, it would be seen as the other manufacturer. I wouldn't flash it unless it was dead or for some other reason needed a flash.
yes, something is wrong with it. Not dead, just funky right now. Happen to know where to find a utility?
well I am hoping that it is not toast. This card was put onto a ASUS K8T800 mobo and ever since then, I am getting full rows that are not displaying right on all screens (POST, BIOS, and OS) althoguht every once in a while it will work just fine. It still does this on the few machines I have tested it on. What I get on the POST and bios screen is pairs of rows that display small diamonds from top to bottom. And lately BSOD once it boots into windows. Anyone seen or heard of this before?
shouldnt be heat. its got a monster sized Tt hsf. No OC. It has been OCed previously, worked fine when set back to stock speeds and voltage, until it put onto the K8T800, now its stuck on stupid.
I had a gf3 ti 500 that would do the same thing. Real flaky. I couldnt find any bios flashes... Now its doing a great job of collecting dust...:(
I now have ati, but i believe you want to look for something called nvflash, or other utilities here
I used to have a ti4400 that I flashed to a later bios, and it improved the 2D image quality a great deal, but the latest bios that I had found must have changed ram timings, because my ram clock artifacted at a same clock that worked with the previous bios. The best bios that worked for me was 4.25.00.34.00, the 4.25.00.37.00 didn't clock as high.
Well I found what I needed, but the funny thing is, the machine that it was going to finally be used in runs it just fine. See the card was given to me after all that weird stuff I mentioned happend on the K8T800 board. So it got replaced and everything worked fine there. The card was tested on a couple of other machines and it was hit and miss. Now I got it in my Dell and it works just fine. Well, so far that is. 4 hard resets and still works fine. Guess I made out pretty good.
I'd still flash the bios, it improved the image quality greatly for me.
To be honest, I think it has been flashed with a recent bios. I kind of remember him saying he flashed it and still had the problem. Even on the original machine he had it on which worked ever since nvidia dropped the 4600. For some reason this Dell likes it.
