BIOS flash failed... what else can I try?
W.O.T. Stang
Ok, so I got my new board today. It's a KN9-SLI. It had BIOS version 1.8 on it. I was all ready to flash to 2.0 (latest version) before I got started. I didn't have any floppys around so I put the BIOS on a bootable CD and proceeded that way.
I started the bios flash with awdflash.exe It asked me what file name, I told it KN9_20.bin. It asked me if i wanted to save the old BIOS. I said yes, and told it "C:\oldbios.bin"
After that i proceeded and it starting writing the blocks. About 1/2 way through it stopped, and i lost monitor signal. I thought maybe it was just updating and kicked the video out. I waited a minute or two and nothing was happening. So unfortunatly i restarted the machine and now I get no POST, but I do get activity from the floppy drive like it's looking for a disk.
After so research I found http://pages.sbcglobal.net/jefn/bootblock.html I tried both the Autoexec.bat method, as well as the ALT-F2 method. The autoexec method makes the floppy read for about 5 seconds and then it just sits there with the light on. The ALT-F2 method just makes the floppy try to read everything i press any key.
Is there anything at all I can try different short of replacing the board or swapping the BIOS itself? I'm not sure why it would attempt to read the floppy if it wasnt going to do anything.
Any suggestions?
that, and if it's doing autoexec, you need to get io and autoexec correspondingly to execute the flash tool with flags to flash the bios. look at bootdisk.com for io
