bios booting problem on K8N-E Deluxe
svet-am
on my K8N-E Deluxe, i have my drives arranged in the following manner:
SiI 0 - Western Digital HDD
SiI 1 - Western Digital HDD
SiI 2 - Plextor SATA DVD-RW
Note that I am not using the nForce SATA controller or the PATA controller at all -- all of my devices are connected to the Silicon Image 3114 controller. There is also no floppy drive attached to the PC. The only drives are those mentioned above.
In the BIOS, I have the Plextor DVD-RW configured to be the first boot device, followed by the HDD on SiI 0.
However, actually booting from the optical drive is hit or miss -- sometimes it works and sometimes it doesn't. Further, whenever things do boot to the DVD-RW, apps like Fedora Core 3 do not see the optical drive at all (even if it just booted from it).
Is this just the nature of the Silicon Image controller? Is it possible to update the BIOS of the Silicon Image controller with updates from the Silicon Image web site?
I am interested in experiences that people have with SATA-only configurations with this board and how to get it to work properly.
As a rule I only use the SI controller if I am putting drives in a raid aray and I have never had any problems.
then how would you install the drives. i tried putting the HDDs on the SiI controller and the optical drive on the nVidia native SATA controller. However, when i did that, it then couldn't see that optical drive **AT ALL** for the boot process.
any insight from there?
Hey guys - I plan to add a second drive to the k8n-e for RAID 1 (mirroring). I overclock 10% @ 220MHz x HTT=4 @ default voltage. I read RAID will not be stable with overclocking. Are you guys able to o/c and run RAID?
