It's a new Gigabyte mobo with AMD cpu. It worked for a couple of days then, no boot, no display, just beep codes -- 2 long-3 long. I swapped the video card, still the same beeps. Is it bad CPU or mobo? I googled but nothing, any ideas?
I will return it to newegg.
Thank you. I swapped-in a different mobo and everything works. I'm surprised because I've had good luck with Gigabyte, not so much with Asus. BTW it's a GA-990XA-UD3, I will return it to newegg.
So what to replace it with? What's the most reliable AM3+ mobo? I don't care for overclocking or fancy heatsinks, just reliable. "Corporate stable" will do.
Having read a thread here on Newegg's horrible RMA, I recommend you take pictures of the motherboard before you send it in, because they are damaging them and returning it as customer caused. Mostly intel LGA boards though but you never know. As far as AMD motherboards go I am more of an Intel guy so I will wait for someone else to recommend something decent. In my Intel builds I use MSI/ASUS and they have never given me issues. ASUS has a horrible RMA policy though so be wary of that.
How was that memory known to be good, as opposed to just never having shown an error during normal operation or during testing?
If you liked that Gigabyte board, just get another. Gigabyte makes very good motherboards but even the best manufacturer can have a lemon slip thru now and then. I'd just get an exchange because the odds of you getting 2 lemons back to back are pretty low.
