I'm having a major problem with .bik files. Everyone i view the audio constantly skips (cuts out/in) every few seconds, it makes them unplayable basically.
This has affected mostly games that use them.
I'm running on an Asus p5q-deluxe which uses the soundmax HD Audio.
I have the newest drivers I can find for it (only 1 set on the asus site, tried to find newer ones but soundmax doesn't even list any and tells you to go to the asus site or whatever) and have tried uninstall, reinstalling them, etc.
I've d/led the Rad game tools player and even using that it skips as well.
Tried turning sound acceleration off in the windows settings, turning off the digital output setting in the soundmax control panel, etc and no luck there.
I'm pulling my hair trying to figure out how to fix this issue. It's audio only, the video itself plays out fine with no problems or anything.
Other specs:
Intel c2d e8400
2gb ram
windows xp (32bit) w/updates
If anyone can help fix this I would be very grateful. I've tried hours searching google, trying out things I could find on it and nothing working.
Other specs:
Intel c2d e8400
2gb ram
