Bing negative cashback?
One should be able to simply add the item to their cart (before using BCB), then close the window/tab, use the BCB link and go to your cart. This will apply BCB to the actual price rather than the higher BCB price.
For instance:
Adorama had LSD AA rechargeable batteries (2 x 4 packs) for $6.99.
When using BCB link, it was $9.99 (minus 3% BCB).
So, adding the batteries at the $6.99 price to my cart, then closing the tab and then using the BCB link, it applied to my cart that held the $6.99 item.
In the end, I saved $.21 due to BCB.
Unless I misread the article and it was about something completely different.
