Bigwater - Big Typhoon
Postal Dude
Hey guys. Can anyone tell me if the mounting mechanism i have installed already with my bigwater is compatible with the big typhoon? Its the Big steel H plate with 2 long bolts thru it. Then on top you've got the 2nd steel H plate with 2 little nuts that tighten it down. thanks
The screw lengths are different, otherwise the H-clips are the same.
will the screw lengths make a difference? any chance of collision>??
Dont wanna remove mobo again if possible
