bigger 940 overclock
woppy1
at the minute im running @3.8 on my 940 and that has peaked @50c do you think i will get more out of it when i get my new ram.
at the minute i can only run my ram in single channel because the ram sticks are too thick on my old board channel 1 was slots 1&3 on this one it is 1&2.
does running in dual channel do anything for the overclock or is it just a bandwith thing many thanks for any replys.
its only an 8% gain in performance running in dual channel over single channel and will not effect your overclock.. you can try going higher.. temps seem fine.. what voltage are you currently running?
it fluctuates between 1.488v and 1.504v temp goes up to 49c
if thats stable.. then you have plenty more room to go..
you are still within the 1.55v limit.. so its worth a shot for 4ghz.. though im not sure if you will get it..
Max temp is 62C stated by amd afaik. Most people will recommend keeping it in the mid 50's.
Once its stable though your max temp is going to be around 5-10 degress lower than with stress testing.
I'd think you can push upper 50's while stress testing, then check temps while gaming e.t.c.
On the topic of temps, when I was working on my computer recently I had it running afterwards for 10min. Decided to glance at core temp, I was idle'ing @ 66*C! Turns out the fan on my true was caught on a wire :eek: Kinda worried about AMD's lack of thermal protection.
When overclocking remember with the PII procs, it's better to keep the temps down than to add more voltage. Or at least that's the scenario I've been running across.
Depending on the BIOS, you can set the shutdown temperature at 65°C if you want. That is something I make sure to check during my very first pass through a new BIOS/board.
the thermal temps actually 69C.. i checked it with my 940.. booted up with my fan unplugged.. loaded it up.. it started downclocking at 65C and shut off at 69C.. i think the 62C number is the recommended limit for stock speeds/stock cooling.. even intel does the same thing.. like the recommended temp for the i7 is 65C but you can go as high as 100C with the i7..
You are a lot more ballsy than I am. I would never, ever (under any circumstance) unplug my CPU fan.
why not.. this isnt the old duron era and p1 p2 p3 era where auto shut downs didnt exist.. all the cpu's including most modern motherboards are designed to protect the cpu by either downclocking the core or automaticly shutting the system down.. if it doesnt then thats amd's problem so in the end id get a new cpu..
Because (in my mind) it is equivilant to running my car into a wall at 80mph to see if my airbag works.
You can subscribe to the thread...no need to keep bumping it.:rolleyes:
I've gone up to 1.55v for normal use with my 940 on air. That was when I first got it and the bios I had at the time defaulted to 1.55v after the first reboot. During this early period I also booted at 1.65v once (still on air) but quickly noticed the problem as two different voltage settings had compounded each other. At the moment I have it at 1.45v and 3.6ghz because this is plenty for me until I get the overclocking bug again.
