bigadv units exists anymore?
thegtproject
Do bigadv units exist anymore? I got a 12 core CPU now but seeing low results:
http://folding.extremeoverclocking.com/user_summary.php?s=&u=568349
Using latest Linux FAH client with this config.xml
<config>
<!-- Configuration file created by FAHClient on 2012-05-05T09:21:43Z -->
<user value='thegtproject'/>
<team value='33'/>
<passkey value='13b9b4c4ab12aa336c4c51ebb564b157'/>
<smp value='true'/>
<gpu value='false'/>
<client-type value='advanced'/>
</config>
you need to set max-packet-size to big.
I have been getting the occasional p6900 on 2 of my windows v7 clients (i7 3930k, and i7 920)
g/l on linux getting BA as I think theyre all 16 core 8101s now, with some 6900 stragglers.
For bigadv, you need to set advancedmethods off and use the -bigadv flag
e.g. -smp 12 -bigadv -verbosity 9
I'm running these on my i7 970, and get 6903/4s about 75% of the time.
linuxforge image, and the Folding client 6.XX that comes with the image.
I used to get 6903/4's but recently have hit a big string of 6901's on my i7 980 / linux.
Code:
max-packet-size         <string=normal>         Max size in bytes of a work unit packet. Can be
                                                  small=5MB, normal=10MB, big=500MB or a number.
Worth setting max-packet-size to anything higher? I got 32 GB of memory on this rig, don't know if it'll help or not.
Unless you want to limit the number of cores used, just use '-smp'. -bigadv gets the turdballs... I mean 8101 WU ;)
-bigadv only gets the 8101 if you have more than 16 cores.
Code:
Yup, set it to "big"
Just got an 8014, not sure if right or not?
Well 8014 is a higher than normal return standard SMP WU, I'm pretty sure its not a bigadv WU as all my bigadv only rigs have never crunched one.
So you're saying to set-packet-size to "big" instead of say... "20GB" as the option does allow for specific values?
Also, a big wtf to http://folding.extremeoverclocking.com/user_summary.php?s=&u=568349... see that 1 WU for 400 pts and 0 for the hours before and after? I have no idea why that happens.
Are you running GPU? GPU units are not very big and complete quickly. You may have had something go wrong with the client or graphics card.
Set the packet size to big, there are only 3 values for that setting. Having more memory than what is needed for the specific workunit/class of work unit does not provide any more performance. The client will not use more memory if you have more than is required. The number of threads, and specific work unit have more effect on the memory footprint.
Nah, I do not have the GPU even running FAHClient. This is all being done on a 3.8 ghz i7-3930K. I may enable the GPU in the future, if it's worth running a GTX 680 on WUs
That points output looks very odd. I am not sure what your problem is at this time. This is all on SMP with the -smp 12 flag?
Post the output of your FAHlog.txt that should help us troubleshoot :)
What do you guys think about my current PPD hourly production since that little hiccup? Do you think I'm on par for a 3.8 GHz i7-3930K ? If not, I'll start posting logs and we can debug. I want to contribute as much as I can :)
Yes, that output looks much better. Give it some time and it will even out if you leave it folding.
