how would i go about running my VM from a ram disk?
Running a ram disk in Native Windows is very easy.
There are several free applications to set this up and they run great.
I don't think you could pull it off with a VM though.
The only way I can come up with is to put a VM virtual disk onto a windows ram drive.
You would need a system with over 12GB to pull it off and that is a minimum number.
Since i don't play with linux, i can't comment on setup but i am 100% sure if windows has it, linux does too.
so what you're saying is that since i have 6Gb of ram, I couldn't run my bigadv VM on a ramdisk... damn
Yea pretty much.
You need a lot of RAM especially if you are running a VM.
Because you will need 6gb for the VMs memory probably at least 6 more for the RAMdisk for the VM to reside on.
BTW, minimum amount of ram you need for a VM is 6, and another 2 to at least run the OS, if you plan on doing more with the system, than you need more, so minimum of 8, suggested of 12.
