Synful Serenity
- Jun 4, 2004
I have looked into installing the Big Typhoon quite extensively, but I still have some questions. I am aware of the fact that due to DFI's non-standard backplate, conventional installation is not possible without longer screws, and I know that the alternative is to reverse the screws coming up from the bottom. Here's where there's some confusion: What are the advantages to using the included metal backplate versus the stock DFI one? Is it some kind of stiffness/stability issue? Also, I haven't been able to find a clear consensus over the use of the foam H....What have most of you with Big Typhoons done?
