Big trouble....
Parabellum
Hello guys,
I have a problem right now that really annoys me.. I had a P4C800-E Rev. 1.02 and a complete stable overclock at 3.75GHz but I was expecting more... One day, I had the opportunity to switch this motherboard for another P4C800-E but with Rev. 2.00 instead hoping to get more powah! At the same time, I had a deal for a *better* power supply (all in my sig). I previously had another Enermax 465W PSU but the "VE" lesser model. I did set up all my new goodies and decided to immediately flash the BIOS to 1021 (I had 1019 installed on my older mobo) and then reformat C:.
Now, the problems are that I can no longer have my computer stable as it was with "superior" hardware.. On my last setup, the voltage was set at default in BIOS and even if I force 1.60V in BIOS, it crashes. What is happening is that the computer simply locks, screen freezes, sound loops, etc. I am using the 250MHz FSB with a ratio of 5:4 to keep my memory to specs. I repeat that it was stable before (ok I know, if it ain't broke, don't fix it......... but I am an overclocker wanting for more!! hehe)
Also, I have noticed that the CPU and system temperature a quite higher than they were. Before, my CPU was idling at 25ºC and now 33ºC. I don't know if it is due to board revision or BIOS... Also, sometimes, after having gamed a while, there is a buzzing sound like "TZZZZZZZZZZZZZZZ" coming from my computer but I cannot locate exactly from where it comes from. I have swapped the PSU for a coolermaster 350W and I did not notice this sound afterward but the computer still crashes like described above.
The way I see it, there are a couple of things I can do :
Reinstall the heatsink and reapply thermal paste.
Flash BIOS back to 1019
Get a thermalright XP-90C
Go buy another motherboard...
Kick myself in the ass for being such a idiot :eek:
What do you think about it?
Thanks in advance,
Para
i believe the buzzing you are hearing is the mosfet coils, take a pencil eraser and move them around while its running, see if that solves the problem
