BIG TROUBLE! Please help ASAP!!!!! I'm Begging!
JMJ
I've never encountered this issue before. I just converted from RAID 0 to RAID 1. I backed up all my data on a 200GB maxtor, I was running WinXP SP1. On a fresh install, it says my maxtor drive is "unreadable". I can convert it to a basic disk, but will lose all my data! I can't lose it, I have a lot of important stuff on there. Please help! Will I be able to recognize it after installing SP2?
I seriously about blacked out at the thought of losing all my data, please please help!
First things, chill, take a deep breath and you know DONT PANIC :cool:
Second things. Check all the jumper settings on the drive are done up right, and that all your bios settings are right. Its maybe trying to raid the drive or something.
If that doesnt work, try the disk in a another box. Or if you havent got another box available, go download knoppix and boot that see if it can read it. My bet is youve got it plugged into a port that is set up to raid in the bios. So check that first, if not knoppix should be able to read it if theres anything resembling a sensible filestructure on there.
I didn't change anything (never opened the box), it was working fine 2 hours ago before I converted. It's on an IDE controller and I never messed with that, I only messed with my VIA controller on my k8V deluxe. I'm going to install SP2 first and see if that helps, I almost have it downloaded. All my drivers and important files are on that disk.
/still in a panic
It was a disk size issue with windows. Installing SP2 fixed it! woohoo!!!!!!!!!!!
