Big Problems MIS Kt8 Neo FSR Help
rogerssa
Problem is I get Windows XP installed it runs for a bit then it locks up goes to a blue screen or it just locks up.
I've tried the Cossair PC3200 and OCZ 2700 memory still have the problem. Lowered the speeds of the memory down and well as the processor.
It still locks up over and over again. Sometimes sooner then others sometimes it goes for a while then locks up.
Any idea what could be wrong? What I should try? I'm out of ideas short of sending everything back and going back to my Barton. Please help I'm pulling my hair out and I don't have much to do that with.
BTW Temps are 31C idle on the processor.
System specs:
K8T Neo FSR
AMD64 3000+
2 256Meg Cossair XMS PC3200 Modules in banks 1/3
ATI Radeon 9800 Pro
Seagate Baracuda 120gig SATA HD
Antec True 480watt power supply.
