Okay, whether it was stupidity on my part, or somethin else i dunno, but heres the story, in short form.
- Friend gave me XP Pro
- I try to install XP Pro
- All is good, it copies all the files (unless i missed something when i wasn't there...)
- Restarts, Goes into install
- Tells me theres and error in SXS.DLL,and setup cannot continue.
- I try again, no go.
- Pop in windowsXP Home, I cant rollback the install to before the mess, and i cant upgrade either without losing unbacked up information, so i install home on same partition, in windows2 folder.
- Now i have a screwed up XP Pro occupying more than half the partition (i have 3 partitions)
Anyways, my question is... Can i SOMEHOW make restore points accesible in this OS (Home) that i made before i tried to upgrade to Pro, or are they gone?
Second question is, what the hell should i do with the first windows Folder, the one currently holding messed up Pro... should i copy all the stuff i need/want out of it, then delete it or what...
Advice is needed on what i should do...
Thanks...
Thanks...
