Big Problem, Possibly Virus
Sloth_Boy
Well, anyone that helps me with this, is a bloody king...
Ok,
My dad brings me his computer about 2 weeks ago, and i had a look, it looked like windows had been currupted had said it needed repairing, and ofcourse, you cant repair windows, well not when i try anyway. So, i try re-installing it, but it kept jamming halfway through and no matter wat a treied it jammed. So i then put another hard drive in and tried to boot the windows that was on that, this time, windows didnt load, it simply locked before the windows loading screen came up. Ok, so i thought, the board must be fualty since ive had other problems in the past, so i buy a AN7 board for socket A, tried that, again, didnt work, so i then bought a new 3200+ (old CPU was a 2000+), again, that didnt do shit. So, i then mixed and matched every other part in the comp including the case and tried no case and still, the same thing, it seemed to be getting worse and worse, so now after all thgat, it just BSOD's when ever it tries to load windows, i try to install windows and it just locks up, so, ive basically replaced the whole computer part-by-part and it still dotn work.
So, im now thinking a bad virus must of got onto the harddrive thats then put itself on to the mobo. And when i replaced the board, i left everytihgn else the same so the virus must of put itself onto the new board aswell...
Now for the questions...
1. Can a virus do all this...???
2. Would the virus be storing itself on the mobo or the CPU cache (also, ive tried clearing cmos and removing battery, no luck)
3. If it is a virus, is there anyway i can remove it form the hardware (mobo, cpu, where ever its storing itself)
4. if it is a virus and i cant repair it, wat should i do, wat parts do i need to replace (hardrives, mobo, cpu).
5. how would my dad of got this virus and wat type of virus can it be???
Please, if anyone can answer those questions and give me anymore info i should no about, then, that would be soo good, i dont think you'd understand how much fixing this comp means to my dad and me, we're not rich and ive spent bloody days on this issue, so please, help!!!..., cheers!!!
First of all, what OS? Win2k or XP?
You CAN repair it, but most people see the first choice of "hit R to reapir" which takes you to the recovery console. If you go past that like you're installing windows normally, it will say "checking for previous versions of Micorsoft Windows". It will find your current setup and allow you ro hit r to REPAIR it and will copy the sys files over again (this is how you do motherboard swaps in XP and keep the install sane).
Issue 2, and no one may believe me. If it's bombing out on the copying of the files (normally DRIVERS.CAB or OEMBIOS, hook up a different optical drive. I must have tried like 3 diffrerent XP discs on one of my rigs and it would not go past those. Turns out because those fiels are so big, the DVD ROM drive I was using wasn't sustaining the transfer. On a whim I threw in an old 40x CD ROM drive and it worked. I now keep that drive handy for my Window installs :D
Can you give a description of the error you see, or it an instant reboot, or a "cannot copy file" error when reinstalling?
We'll get ya running.
Oh yeah, PSU can cause data corruption as well. How reliable is the unit in that rig?
i highly doubt that it is a virus that managed to flash your bios and corrupt the motherboard, however i remember that back in the day there were viruses that messed up your bios but you usually had to boot from a floppy disk for them to do their damage.
i would recomend doing as the above poster said and use a different power supply and cd/dvd-rom drive
My PSU is a Antec 380watt, high quality, i tried another one like i did with everyother piece of hardware. Something that ive noticed (ive posted this on alot of forums) is that, people are saying, if you change mobo, then you have to repair your windows install, right. Well, to start with, the whole reaosn i went through this fixing thing is because windows fiels were currupted, so i have nothing to repair, my only option is to start a new re-install. Well, i might try that..., ill also try flashing the bios...
And, for the error message tihng, i dotn get one, it either jams or i get a ""!!! | BSOD | !!!""
ill try again though once im happy with my replies..., then, if that dotn do it, techie it is, i want to see if he knows wats wrong, ive never ahd to result to a tech before ecpet for a tiem when everytihng on my hardrive currupted, all 160GB of priceless memroies and video, anyway...
Yeah, continue the help!!!
#1, Where did you buy the 3200+
#2, Did it come PIB retail or OEM
#3, Can you scan and post a picture of the 3200+ here
#4, List every components specs including the amperages on the power supply, no one gives a crap about the voltages unless they are REALLY terrible.
Since you didnt list it specifically, did you try different ram? Bad sticks can manifest in all sorts of strange ways. If you can boot the computer to a memtest386 disk and run it for a while, that will at least help to eliminate the ram, provided you havent already tried using some other working ram.
No.
My suspects: 1: CD/DVD drive, 2: RAM, 3: Power Supply, 4: Bad OS CD, 5: hate to say it, but: User
==>Lazn
Well,
I wasnt the user, my dad was, and knowing him, hes just starting using computers and when hes on the net, he'll click everytihng that pops up. I wouldnt be suprised if there are a bunch of viruses on 1 of the harddrives, thats probably wat would've caused the problem to start with.
Anyway, im going to try flashing the bios, ill also try different IDE cable or CD-ROM, ill also try and instlal windows of both my disks, and ive tested every peice of ahrdware (mix and match) so its not ram, so looks liek tis norrowing down to harddrive issue or soemtihng.
I'll get back to use...
Thanks for all the help guys
