Big motherboard problems... Stupid BIOS
erorr404
The BIOS of my new MSI 865PE Neo2-PLS motherboard is very strange.
Instead of normal dividers it has memory frequencies which act as them, and none of them allow me to run my CPU (133 MHz) and my PC3200 RAM (200 MHz) at their stock speeds. I am forced to run one of them underclocked/overclocked in order to achieve stock speed on the other.
The second and biggest problem with this BIOS is that I can't raise memory CAS latency to 3 - it only allows 2 and 2.5. The Crucial stick of PC3200 RAM I have is rated at 3-3-3-8. I can change the last three timings to their proper speeds, but not the CAS. If I set it to BY SPD, it still does not change the RAM to CAS 3. Because of this, the computer won't boot when I set the RAM to it's stock frequency of 200 MHz.
I have the latest BIOS.
Any suggestions? Is there any way to get around this?
Thanks in advance.
