bid adv wu stuck?
Filter
seems like its been on 68% for a long long time now wu is a 6900
restarted it and still seem stuck
should i delete and restart?? all cores and threads are at 100%
[00:53:35] - Machine ID: 2
[00:53:35]
[00:53:35] Loaded queue successfully.
[00:53:35]
[00:53:35] + Processing work unit
[00:53:35] Core required: FahCore_a3.exe
[00:53:35] Core found.
[00:53:35] Working on queue slot 01 [December 29 00:53:35 UTC]
[00:53:35] + Working ...
[00:53:35]
[00:53:35] *------------------------------*
[00:53:35] Folding@Home Gromacs SMP Core
[00:53:35] Version 2.22 (Mar 12, 2010)
[00:53:35]
[00:53:35] Preparing to commence simulation
[00:53:35] - Ensuring status. Please wait.
[00:53:45] - Assembly optimizations manually forced on.
[00:53:45] - Not checking prior termination.
[00:53:48] - Expanded 24864700 -> 30796293 (decompressed 123.8 percent)
[00:53:48] Called DecompressByteArray: compressed_data_size=24864700 data_size=30796293, decompressed_data_size=30796293 diff=0
[00:53:49] - Digital signature verified
[00:53:49]
[00:53:49] Project: 6900 (Run 32, Clone 19, Gen 12)
[00:53:49]
[00:53:49] Assembly optimizations on if available.
[00:53:49] Entering M.D.
[00:53:54] Using Gromacs checkpoints
How long has it been stuck? You only posted a partial log, so it's not really possible to determine anything from that.
And is it still stuck since you restarted the client? Have you tried rebooting the PC? If none of that helps, delete the unit. There's evidently something wrong with it, so there's nothing you can do other than get rid of it and move on to the next one.
yeah did all that.
just deleted it.
