bh5 question...
gclg2000
Are all memory boards that use bh-5 the same bh-5.....as in.....
bh5 3200 chips = bh5 3500 chips = bh5 3700 chips.....
I'm in the market to get some along with the OCZ DDR booster (which almost alows unlimited voltage for RAM) and is there any difference to get the 3200, 3500 or 3700 boards, or they one in the same? Can they all take alot of voltage and THAT is what gets them up in speed and keeps the low latencies?
Anyone with these chips (and the OCZ booster) plz help or anyone who knows some info...
I have .. LVL2 Mushkin BH-5 pc3200 great sticks .. 1 gig kit .. expensive and super hard to find anymore so good luck in your search
Chips are the same yes, PCBs and arrangement of capacitors and such may vary, capacitors are going to have the most effect on the kinda voltage the ram can take (outside of the actual chips I mean), PCB effects cooling and reliability (expansion from heat etc changes things).
The top mfgs do everything right from top to bottom, you usually start sacrificing one or more areas when you go cheaper.
