BFG Tech GeForce 7300 GT 512MB
oshow
alright, i just ordered a BFG Geforce 7300 GT from newegg.. i havent been up-to-date with the current computer related stuff. im just wondering if it's good enough to play CS 1.6, CS:S, Madden, NBA Live, and maybe some BF2. my Sapphire Atlantis 9800 PRO worked really good with all the games listed, so i thought a 7300 GT would be a improvement seeing that the 6800 was supposedly better than the 9800. im also running AGP not PCI-e. also will it run equally or better than my current one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143102
some notes..
Asus AS8-V mobo
Intel P4 L775 2.6 Ghz - Retail Heatsink
2x 512 PNY DDR 400 PC3200
Western Digital Caviar 80GB 7200RPM SATA HD
Fujitsu 120 GB 7200 RPM IDE Ultra ATA
Thermaltake 500W Power Supply
and about 5 fans excluding the CPU Heatsink and Power Supply Fan.
how much better? will you be able to notice a difference? i might cancel my order if it is.
Big time difference.You will be glad you changed your order. ;)
write newegg an email after the fact and they will refund the restocking fee...
some notes..
Asus AS8-V mobo
Sorry to hear that. The 7300 just cant compare to a 6800. I don't think its even close to a radeon 9800. You would be a very sad person with that 7300.
get the 9600gt for 60 bucks
go to hot deals for more info
the 3850 is kind of out of my range money wise.. other than that, the 3650 is the next best one?
nösferatu;1033048384 said:
NO. 6600GT beat 9800Pro, 7300GT very close if not equal to 6600GT, so a big NO to You.
Did you read what I wrote? You basically just repeated it, so I am not sure why you are shouting NOs on the internet.
I thought You basically said that 9800 beat 7300GT ? I'm saying that 7300GT will beat at least the Pro version of 9800.
I'm sorry if I misundertood Your post, my bad.
