I just got a BFG GTX285 OCX from newegg. I guess its supposed to be overclocked from the manufacturer:
Core Clock.........702MHz
Memory Clock....2664MHz
Shader Clock......1584MHz
But anyways, I installed rivatuner v2.24 and check the system settings where it shows the current cards clock speeds.
In the first pic I have the "Enable driver-level hardware overclocking" box checked and its also set to "standard 2d" with lower core clocks. I am assuming this not the setting I want.
So I changed the drop down option to "performance 3D" and it brings my Core Clock up to the 702MHz and Shader Clock to 1584MHz but my memory clock only goes to 1332, its supposed to be at 2664MHz.
Is there something wrong with my card since its not at the speeds its supposed to be out of the box? I normally don't use rivatuner, just d/led it to verify my OC'd speeds. So if I don't use rivatuner are my speeds not what it should be out of the box?
