BFG GeForce 9800 GTX
gamerx11
Finally had this arrive in the mail and will be testing it out when I get in the rest of my parts. Now, it is pre-OC'd. I have heard that you can't overclock your GPU if it was bought pre-OC'd. If this is true, then why is it not possible to overclock the GPU anymore?
theres no reason why you wouldnt be able to oc a fac oced card.
Came across someone saying it in a youtube video, was a bit skeptical. Well then, supposedly it overclocks well so I might give that a try. Thanks for the info.
Nice what kind of case and cooling? I heard they are great overclockers.
I used to use a CM 832 and still use the ZeroTherm Nirvana <----- great hsf, on the cards it was stock.
