BFG 800GT Problem-Just getting a black screen
Nap
It appears other people are having the same problem, but what makes it especially weird in my case is that I had the card plugged in and working for almost a week. Then I started having problems with my RAM, so I went in to adjust some of that and after plugging the computer back in, all I get is a black screen while all the fans and whatnot spin normally.
Specs: Q6600
BFG 8800GT OC
4gigs (2x2) Patriot
ABIT IP35-E
Samsung Spinpoint 500gb
Antec P182
I bought this card from Best Buy, so if it does turn out to be needing replacement, does anyone know if I can just take it back there or will I have to deal with RMA? Thanks for any responses.
can you boot into safe mode? If so,reinstall the drivers in safe mode.First time I installed my card I got a blank screen also,I booted into safe mode,installed drivers and it worked from there.
Try re-seating the card. If still greeted with a black screen, it would be worth seeing if Best Buy would exchange it for a new one.
Thanks for the responses. Ended up all I had to do was re-seat the card. :)
I have the same problem. The BFG 8800GT OC that I bought from Best Buy worked for a week. I came home from work to find that my computer was off. I left it on when I left. It would not boot. The blue power LED will turn on but everything is "still" in the case. No screen, no beeps, nothing. I checked all connections, power, pci, etc. Swapped out for my 7800gt and works fine.
CM stacker
BFG NForce 4 ultra
2x 515 Corsair xms ddr 400
Antec neo 550
DVDRW
WD HDD
I'm taking it back tomarrow as they open at 5am for "black friday.
Ive read about the compatability issues for pci version 1.0, 1.0a etc. I hope theyre wrong.
Good luck. Hope they have one in stock. :( Swapping out and it firing up with the 7800GT does help your case when you go to replace it at Best Buy.
