BFG 7800 gt oc
DOes it have any way to overclock. i was playing PARAWORLD and in all HIGH my video card freeze a lil bit. but i have also 1.5 gb ddr and a AMD athlon 64 3200. please any advise will be good.
Does that happen to other games too? Do you know what temperatures you're getting at idle/ load?
yes that happens to me with s.t.a.l.k.e.r shadow of chernobyl . what temp it should be ?
o it is my video card the 7800 gt oc that cna not run those games in high?
so is 1T 2x512mb better than 2t 4x512 or 3x512 in this case? also single channel slower? or does extra memory make up for it.. guess it depends on the game but i always wondered and just went with 1t 2x512 or 2x1gb so far.
as far as stuttering.. your cpu seems bit underpowered.. if you play higher res less cpu is used.. what resolution do you use for these games?
most of the game on 1024x768 and the ones that accept 1280x1024 i always try to play in full, but i add another memory of 512 ddr taking away the dual channel function because now i got 3 memorys , and still the same, o my video card is getting old o my cpu is slow for this ne games./?
