Hello. I'm using RivaTuner to overclock. I unlocked the extra pipes and shader, so it's at 16/6. I already changed the DisableInternalClockTest setting in the Power user tab. I thought it was OCing fine, but I noticed after running 3DMark 2003 that it had the core still at the stock 350MHz. I OCed it in RivaTuner past 400MHz and the 3DMark score didn't change and it still read 350MHz in 3DMark. The RAM overclocks accordingly, so this is only affecting the core. Is there anything I can do to overclock the core? TIA.
