BFG 6800GT incompatable with DVI KVM?
RanceJustice
Hey guys... I'm having some issues with my DVI KVM switch. Here is my setup -
Computer 1: AGP GeForce 6800GT (BFG) DVI connection
Computer 2: PCI-E GeForce 6600GT (MSI) DVI connection
Monitor: ViewSonic VX2000 DVI connected (1600x1200)
KVM: Linkskey 2 Port PS2 KVM Switch.
The biggest issue is a huge amount of multicolored horizontal scanlines that occur at odd times. For instance, when I click on an icon in windows explorer (say a folder or whatnot) sometimes there will be three or 4 periods that change in color, often green or pink. Then when I boot up certain games (Planetside, Splinter Cell CT), I will get a HUGE amount of scan lines in greens,reds, blues, pinks and yellows that totally distort the image. The scanlines flicker and change color. It seems like this happens for any game that has an opening sequence. If I leave this alone long enough (say on the server select screen of planetside) the monitor will continually try to turn itself off and on again to refresh. Now, if I manage to actually get into the playing portion of the game, there are no issues.Likewise, games like world of warcraft with no introduction sequence seem to be fine. Playing divx files at full screen also seems to be ok. THIS HAPPENS ON COMPUTER 1 ONLY WHEN IT IS HOOKED UP TO THE SWITCH.
The second issue is most notible in games that sometimes keys "stick" That is to say, on completely random intervals if I am holding "W" to run forward and stop pressing it, my character will continue to run forward until I tap W again to stop it, or for two or three seconds. I've seen this happen with the WASD keys so far. I don't know if this could be in any way related, but it is annoying none the less.
This is the second switch I've gotten from newegg, RMAing the first one thinking it was a faulty unit.
EDIT: I have successfully recreated the issue on computer 2, so I'm pretty sure it isn't just the video cards.
Does anyone have any idea whats wrong with the switch, my setup, or something?
