Alright, to save you from having to read all this garbage, here's my end-all question: Can you suggest a good PS of 480W or better for running a 6800 Ultra (AGP)?
Specs:
AMD Athlon64 3400+
DFI Lanparty UT nF3 250Gb (mobo)
Premium 600W Power Supply
1GB Ultra DDR PC3200, 400MHz
Nvidia Geforce4 TI 4800
Creative SB Audigy2 (is the only other PCI card in the machine)
(case lights, temperature digital readout, fans on top and side: all use power)
Here's the full scoop: I got my BFG 6800 Ultra this Friday. I had been cranked for some time, so I already had newest drivers and even a few demos lined up.
So it didn't take me all that much time to swap it out from my old GF4. Swapped it out, new drivers installed, first thing I do is run 3DMark05. Without tweaking for anything like that, I get a 5200-something (like 5264 or something like that). Not bad. But it was on my lunch hour and I needed to go back to work. Knowing I was going to my parents to eat that night, I went ahead and shut the computer down because I knew I wouldn't be using my brand new 6800 Ultra for a few hours. (NOTE: So that's a total of about 30 minutes where all I did with my brand new working card is run 3DMark05.)
Warp to 6 hours later: I rush home, push the power button on the front of my case to crank up my machine. Blue lights come on, power supply begins to hum. Literally 1 second later: silence. I do it again. The same. The system begins to boot only to die back down 1 second later. The fans all try to start spinning, the lights do come on, but it all goes back to nothing within just a second (or less).
It is exactly what happens when you try to boot the system with no vid card in there at all! There is a safety feature on my mobo where if there is no video card plugged into the machine, it will keep the computer from booting. It acts the exact same way. I tried it. =(
I suspected maybe one of the power plugs was bad that goes into the back of the 6800, but when you unplug either or both of the power plugs from the back of the card, the card beeps real loud (or at least, it starts to beep for the second it's up and trying to come on. After the split second it tries to crank up, everything dies, including the loud beeping noise from the card.) So if a power plug wasn't giving juice the card would beep.
I then unplugged everything possible that wasn't needed from the PS to see if that helped. All the lights, fans, everything. Only the necessary stuff left on like main HD, mobo, etc. That didn't make any difference.
So I stick my GF4 back in to research this on the net. Computer boots and works just fine. I am wondering about some of the Genie settings in my CMOS (like AGP voltage and the like). So I start fiddling with settings
D) and swapping the cards back and forth after each change to see if anything does it. That was a pain in the rectum as my mobo has a little lock on the AGP slot that you have to push up from the underside to get it to let go of the card. End result of all the changes: Nothing.
I finally call BGF. The guy says to leave all the mobo settings to factory defaults (except AGP aperture size, I guess). But the guy says to flash my bios. So I head over to DFI's website. It's down (of course
) so I go ahead and post to DFI's forums. They are pointing at the power supply.
On to my power supply: It's a Premium 600W. Now granted, 600Watts is supposed to get the job done. But it cost me 70 bucks. :\ One guy (on another forum, and not in response to me) posted that you don't just buy a 600watt PS with blue-light fans on both sides and a cool little window for $70. The numbers are fudged somehow. I would have a tendency to agree with him. I even sorta figured I was buying junk when I got it; I was just throwing my dice on the table and hoped it was gonna get the job done. Could my power supply just not be getting the job done? If so, why did it work at first?
The next day I checked DFI's website. The date when I flashed my bios when I first got the mobo (back around Oct/Nov I think) was the latest bios I could find. I should be up-to-date there. So I'm still trying to figure out if there's newer bios flashes out there (official only, btw). Haven't called the BFG guy back cause I'm not sure they'd have another suggestion.
No store around here had a PS higher than 430W in stock (including Staples, Best Buy and Circuit City), so if I go that route I'll just order a darn good one from someone like newegg. No "mom-and-pop" computer stores around here that I know of either. =\ No one I personally know has a computer with a PS bigger than 350W with a regular AGP slot (all other peeps I know have PCI-E) so I can't test to see if the card is bad.
The Tigerdirect description of my PS says "And the Premium 600Watt ATX power supplys innovative Thermal Overload Cutoff Protection shuts down power safely if your system overheats." Could this have anything to do with it? It won't ever boot at all, even after having been off for hours. I even tried running the computer all night with the GF4 and then quickly swap to the 6800 (like I did on my lunch break that first day). That doesn't do it. Could a fuse be blown? I don't really care about that dumb PS, but is that really it?
Could I have burned up my video card??? Gosh, please say no. I did run 3DMark05 on it first thing. But nothing gave problems. The test ran just fine (with no artifacts or anything like that). The computer shut down just fine. I didn't run it for very long. I didn't even leave the machine running.
The card has seen a total of about 30 minutes of runtime. =\ But the computer acts the same way if I have the card completely plugged up, and no video card in there at all. Only stays on for a second.
I probably didn't fry anything else in the system either, because the computer works just fine with the GF4. Everything points to either the video card being bad or the PS sucking. The vid card didn't ship bad 'cause it worked at first. I don't see how I could have screwed anything 'cause the machine acted just fine during that first run (no immediate shutdown, no visual errors, no extremely hot case, etc) and it even shut down properly. I don't see how a fuse could be blown in the PS cause it's working with the GF4.
I'm out of ideas/options, except to try and get a good power supply. I've been railed on before for buying junk, and a PS is not a component to play around with.
Any ideas?
Any suggestions on a good PS? (What about OCZ's. Are they good PS's?)
Thanx, guys!!!
Specs:
AMD Athlon64 3400+
Any ideas?
Thanx, guys!!!
