Bfg 6800 Oc
Wicked_Bass
With this card can the pipelines and such be unlocked to make it an ultra? If not what cards can do this!
Thanks,
you can use riva tuner and unlock extra vertex for sure but for the extra 4 pipes you have a 50/50 chance. BTW you cannot flash a 6800nu to gt/ultra due to the type of ram used on the 6800nu (DDR1) 6800 GT/Ultra (DDR3)
Yes it can. I unlocked mine. But it's probably a 50/50 chance on them ebeing operational. But, BFG is tha Shizznizzle! :)
BFG Tech comes with every card you buy from them is overclocked, no matter what card.
I have a Nvidia GeForce 6800 GT
Unlocking the extra pipes and VS does not an ultra make. Although some have gotten some great OC out of the 6800 dont expect ultra performance.
Wicked_Bass said:
KevinO What did you use to unlock it ? Riva Tuner?
Thanks
Yes with Rivatuner and mine came with the copper dual fan heatsinks.
