BFG 6800 GT OC Benchs
88ccNutz
Ok I recently pruchased the BFG 6800 GT OC to upgrade from 9800XT. My system right now is a P4 800fsb 2.6c overclocked to 3.12, my memory is Kingston Hyperx pc4000 timings are 2-3-3-5. Video card is running at stock speed. What kind of scores do you guys think I should expect to get from 3dmark 01,03 and what kind fo settings will I be able to run Doom 3? Thanks anyway help appericated
12 Axes said:
Slightly lower or the same in 3DMark2K1.
Double 3DMark2K3.
Sorry if I act like a noob but could you please explain to me what you just wrote I dont understand?
With such a powerful video card, 3DMark01 becomes more CPU dependant. Since you're not upgrading the CPU, your 01 scores probably won't show a huge improvement.
Your 3DMark03 scores, however, should roughly double.
Make sense? :)
Yes I understand now but what kind of scores should I expect with 03. I never really did a benchmark with my 9800xt didnt really care to at the time cause it was a kick ass card
Are you retarded or just having a wishfull think?
If you have the card, run the benchmark and tell us the answer!
If you are just wasting everyones time, go Google an answer.
Des.
Yes this is a flame. :mad:
01 = ~20k
03 = ~11k
those would be some fairly average scores for your setup.
Well I ran some benches on my GT before I got rid of it
2k1 I got 19,5xx stock settings
2k3 I got 10,999 stock too :)
this is BFG so its a bit oc
i OC'ed it a bit mroe i got 11,5xx in 3dm
Des.
Damn bro chill out whats your problem? :confused:
Des.
mabye he wanted to see if his system is holding up to other with similar setups
a common and good concern
