BFG 6800 GT idling at 75C?
PKFGimpy
I bought a BFG 6800GT about 7 months ago and it has been running smoothly until I got a Dell 2405FPW.
After purchasing a Dell 2405FPW and playing WOW at 1920x1200 resolution, I've been noticing that my video card is locking up my system sometimes. The only resolution seems to be underclocking the card.
Now, I'm not sure if this is the problem, but I have a feeling that my card is simply overheating. It idles at 75C in a 20C room, and maxes out in the mid 80's. I'm not getting any artifacting or anything on the screen before the lockup, I'll just be playing normally and suddenly my screen will freeze up with crazy patterns of color on it and some sqealing noises from my speakers. I'm forced to reboot.
I'm positive it is video card related since overclocking the card causes these problems to occur more frequently, and underclocking the card gets rid of the problem entirely.
The fans on the card look perfectly fine and I have no modded the card in any way.... so any ideas?
I have a tube of artic silver thermal compound. Should I remove the heatsink/fan and try applying some? Or should I perhaps pick up one of these suckers? Arctic Cooling NV Silencer 5 VGA Cooler (Nvidia FX 6800 GT, Ultra)
Anyone have any more advice? I'm pretty sure my card has been at these temperatures since I purchased it 7 months ago, because I know I was not very successful in some of my meager overclocking attempts early on.... heck, its not even stable at the defaults.
My card has gotten hotter over the last year too. I am not sure why and I am sick of trying to figure it out so I bought a Zalman 700CU and everything now works just fine. My card would always freeze in games at 92C but no longer is that a problem. The card seems to reach 79C at its hottest now.
One of my theories is that either the cards are getting old and wear and tear is making them hotter or the drivers that NVIDIA is putting out is doing it. Hell, even my brother's 6600GT freezes in BF2 if you don't put the big costco fan up against the card.
And yes you have a heat problem. The video card just turns off when it overheats and you hear high pitched noises. I think mine idled cooler than yours.
Ok, well, what cooling solutions do you guys recommend then? You mention the Zalman 700CU, and I posted a link to that Arctic one... I really don't know much about these products, so I'm all ears!
Oh, and one more question:
How can I be sure that the stock fan on my 6800 is revving up to full speed when its under load? I've noticed that when I reset my computer I can hear the fan rev up and then down again, but I never hear it rev up when I'm gaming.... could something be wrong? Is there a way for me to forcefully get it to rev up?
I have the same card. Mine idles at 70 degrees. It gets up in the 80s sometimes and never has any problems.
It doesn't seem like heat is your issue since your not even hitting 90 degrees.
Might wanna try some new drivers, and don't forget to run driver cleaner.
I think you should be fine. My eVGA 6800 gt idles at around 64 and it goes up to low 80's when playing games. The throttle down point isn't until 120 degrees. It could be your overclock on your card as different games put different amounts of stress on your card, but it could also be the driver. I just went from 77.72 to 77.76 and I know for sure CS:S runs even smoother.
Those temps do sound a bit hot. Get yourself a NV5 or VF-700Cu to cool that chip down. I run my 6800GT @ 410/1100 using a VF-700Cu with temps at 79C max on load and 59C idle. The room temperature is pretty hot at 79F. Here is a good link for the Zalman VF-700Cu info. You can see mine on page 8.
Another vote for the VF-700cu, its a great cooler. I've got my 6800GT running at 425/1100 with some good copper ramsinks and idle it sits around 49-51c, and loads at around 62c, quite a difference from the stock cooling.
Ok cool, I'll have to look into this some more.
And when you say you got some nice copper RAM sinks, were those included with the HS/fan, or is that a separate modification entirely? Is this important, or would just the new HS/fan be enough?
One other question :) My tube of arctic silver thermal paste is probably about 4 to 5 years old now.... does that stuff ever go bad, or can it still be used? And do you think it would be worth removing the HS/fan and applying my thermal paste right now?
And to all you Canadians out there, have any recomendations on where I could order this stuff from?
The one's that come with the Zalman are aluminum ones. Someone in the VF-700cu thread though ordered some OCZ BGA copper sinks (Newegg link for illustration). I'm not sure if they make a ton of difference, but they are quite aesthetically pleasing when paired up with it. :D
I recommend the 700 with seperate heatsinks over any silencer. The reason being is that the silencer requires everything to be co-plainer to operate at its best. If one RAM package is 10 mils higher than the other can serverely degrade optimal contact. The 700 provides direct contact with all devices a moves a good quantity of air over all devices.
The only advantage the silencer has is direct exaust but that doesn't make a huge "performance" difference.
-tReP
Oh, as a further point to mine, I get those temps at 12v, but on the plus side, the Zalman is practially silent at any voltage, and from the sounds of it, a great performer even at a lower voltage.
I have wondered that too. I never hear changes in speed when mine gets hot. When the computer boots it is nice and loud. It throttles the clock speed at 120C but mine never even would get anywhere to that hot. It would die at 92C.
I had the same problems you are describing. I tried installing the different coolers and it didn't help. Finally I called BFG and setup an RMA. They sent me a new card. I mailed them my old one. The new one works great. No more problems.
Does anyone have any more info about the fan speed? I'm really curious as to why the fan sounds like it never maxes out even under full load.
I have a theory about those cards. Mine would do this too, often popping up the thermal warning during games, and occasionally rebooting my system. If I took the card out, and blew off all the dust, (even if there was just a little,) the card would stop doing it for a few more weeks. I don't know where the thermal sensors are, but I was thinking that maybe dust would collect near it, and cause it to read wrong or something like that. I could be wrong, but it happened a few times while I had that card, and each time I blew the dust out, it fixed it. I suppose the fan could have been collecting dust as well and caused something similar.
I'm using Arctic NV Silencer 5 rev2s on my 6800GTs now and they work great. They don't really cool any better than the stock coolers, but they're very consistent, they're quiet, and they exhaust heat out the back of the case which helps the whole system. I recommend them.
But does anyone know of any way to verify that the stock fan is reving up to full speed? Are there any apps out there to monitor or control this??
I tried NVTune from the NVidia website, but you need a motherboard with the NForce chipset to use it.
I'd check it out if I still had my BFG HSF on the card.
What about my arctic silver thermal compound? Will a 5 year old tube of the stuff still be good? Or does it go bad or lose its conductive properties?
as long as its been stored with the top on it and kept from extrem cold temps it should be ok
Just letting you guys know that I picked up the Zalman the other day and it was totally a worth while purchase.
All my temps have dropped over 20C and allowed me to clock my 6800GT at 420/1100 (as opposed to underclocking to 350/970).
Thanks for the advice :)
Let us know what temps you're getting after the AS5 has cured.
I'm asuming that the VF700-CU fits inside the stock bfg heatsink right? If so I'm going to purchase one of these also. My card will hit over 80C load and idles around 62C. I thought it was because my computer room was getting to hot and have already spent 120 on a window mounted ac unit :( I don't know why these cards get so hot, I have a thermaltake xasier 5 case so that should be enough airflow for the inside of the case.
